PTO side outer oil seal only in a full gasket set.. Anybody have any aftermarket part numbers for it would be appreciated
THX deererunner..
Gear Box oil seal #.
There should be 3 numbers on the side of any crank seal, not necessarily this number but a number such as 30-62-10
(that means 30mm ID, 62mm OD, 10mm Wide)
Ken
Ken
deererunner
Maybe I should have been more specific,This seal is located outside the crankcase . It keeps the gear oil in that lubes the drive mechanism for oil and water pump. This seal has an outer steel ring as used in automotive applications. It is NOT a crankcase seal..
Mean Green
The seal is JD part number M68123. No longer available. If you take your part number to you local JD dealer though, they might be able to find someone in the system as they network, that has it in stock, GL on that one.
deererunner
I found it through Federal Mogul seals, It came up as a 223520 . Thanks anyway Deererunner.........
