I have a custom sled with a 400 quad plug motor and need to find two flanges to give me the right angle for my carbs. They are greater than 20% now and spit gas out of the carb. I was told to level out the carbs and this will go away. Lead me in the right direction would ya! Thanks, cory
I know some of the older deeres had these plastic angled spacers.
carb intake flange for leveling carb out
outlawbulldog
If you can't find what your looking for, some old sleds used a 2" (bakelite)?? I think that is what they were made of, they were kind of brown in colored spacer/insulator. If you got that then you could have it milled to the angle you need..
hope this helps
hope this helps
You can also make a custom adapter. I know several guys that put Miks on all there vintage sleds.
It will take a couple of hours to fab them up but not that tough to do.
Use a 1.5" 45deg elbow and cut it in two. Then weld on flanges made from 1/4" flat stock with the appropriate bolt spacing and throat hole.
Todd, that would be easy in a single carb sled, But on a duel carb sled a person would have to have every measurement right on the nuts so both the adapters flowed the same & were the same length in the middle & on both ends, this a delema I'm facing when installing a big 440 twin T7 engine in a Snowfire, I will need some kind of angle adapter to get the 36mm Mikuni's to set horizontal, & be exact so to make Max power..
That is why I'm leaning toward the bakelite spacers milled on one side to the angle I need..
Interesting concept you have going there. Is the existing opening big enough to accommedate the quad heads?
My plan is to use some type of hood that gives it a more race look. kind of like a modified 340/S type hood ( thus the name 440/S project - S could also mean Snowfire ) I've also looked in to a inverted Snowfire pan for a hood, this gives it more of a Thunder Chicken look, also " kinda cool looking "
All still a ways off as I'm waiting for my machinist friend to make me a Hex DD front shaft to mount the liquifire drivers to..
Oooo,, I like the belly up idea. Use the spindle holes to mount a pair of driving lights. I bet you have an NOS pan already.
You going to extend the steering post to complete the SST look?
Steering post & handle bars have been cut off & modified to use the CC bar look.
