Idle Help
Decker
Idle Help
Post by Decker »
well,, got her going, got some snow, runs great. but it wont idle tried to shorten the throtle cable to bring the slides up, still wont idle. i need help
Thanks, Decker
nothin smells better than a diesle in the mornnin cept mabey a 2 stroke
Idle Help
Decker, not sure what sled your working with but you should NEVER have to raise the cables to adjust the idle, ( that will also screw up your WOT slide position & might also make the slides open at different times IF using twin carbs)
There has to be a problem in the carb/carbs re clean & pay particular attention to the pilot jet & or the idle circuit.
Joliet Jake
Idle Help
Post by Joliet Jake »
Decker with out going into a whole carburetor discussion here, you need to make sure that those carb slides are DOWN or as close to al the way down as you can.
As the slide opens the signal for the idle system is reduced. Set your air jets to factory spec and then go from there.
And don?t set your idle with the cable length
The idle is set with a large screw with a spring on it on the side of the carb,. You then adjust your cable to that setting.
.Go on line and find the manual on your carburetor, it will guide you.
Good luck
72 300
75 LIQUIFIRE
76 LIQUIFIRE
78 LIQUIFIRE
78 CYCLONE
80 TRAILFIRE
81 SRX
83 LIQUIFIRE
83 SPRINTFIRE
88 650 INDY
94 MACH Z
2000 MACH Z
2005 MACH Z
S 35 BONANZA
Decker
Idle Help
Post by Decker »
the slide position didnt actually change, but the cables were from a polaris triple, and their was alot of play in them, witch led me to believe that the motor wasnt getting enough air, and thats why it was dying
