75 JD 800
Hansy
75 JD 800
Post by Hansy »
When i first got my sled about a month ago the engine was seized, i filled the cylinders with penetrating oil and let it set for a few days until it freed up. Now it will rotate but only half a turn so i used a borescope and looked in the cylinders and the left piston looks like it has two little square type things on the edge of the piston almost directly across from each other. Any ideas on what they might be and what i should do next?
big danno 1970
75 JD 800
Post by big danno 1970 »
sounds like a good candidate for a complete tear down. Inspect all parts carfully and replace as necessary including crank seals.
Hansy
75 JD 800
Post by Hansy »
yeah, that's what i thought. i was hoping i would be able to ride it this winter and then i would pull it apart in the spring and redo it. oh well there isn't much i can do about it
Hansy
75 JD 800
Post by Hansy »
i will try that but i don't think that's the problem cause i can rotate the engine one half turn which brings the piston from bottom to top but it won't go back the bottom unless i rotate it backwards.
75 JD 800
Only way to know for sure is spend some quality time with the engine and a few sockets.
Hansy
75 JD 800
Post by Hansy »
yeah, i will hopefully get a chance to do that this week cause it should be rather quiet at work seeing as it is four days till christmas
75 JD 800
As that is a very nice condition machine you have and only built one year, I would not be affraid to put the money into it.
Hansy
75 JD 800
Post by Hansy »
yeah, i was thinking of repainting and getting new decals for it. I don't know where i would be able to find the correct paint, the decals i'm not worried about cause my wife can make them for me seeing as she is a graphic designer.
Hansy
75 JD 800
Post by Hansy »
Well i pulled the heads off yesterday and found some crap on the left piston, so i cleaned it all off and put the head back on with a couple nuts and then slowly turned it over with the pull start, it rotated probably three or four times and then stopped so i pulled the head off again and there was nothing there so i pulled the other one off too and there was nothing there either. ant ideas what might be causing this? could it be a broken crank?
75 JD 800
Hansy,
Not to sound rude, but you need tear the engine apart to find the problem. There is no point to guessing at it. Merry Christmas :)
75 JD 800
Complete step-bystep instructions and pictures are in the Service Manual.
Very well written for any level of skill in engine teardown repair and rebuilding.
If you do not have one it is a great idea to lay your hands on one as it covers not only the engine but chassis, steering, electrical ect.
75 JD 800
Hansy, I'll look into my Cristal Ball first part of next week & let you know what is the problem with it, In the mean time as JDT has said, :wall: get a Service Manual for your sled, as you will need one to repair your engine..
Richard
75 JD 800
The guys have this covered pretty well. Unless something is jamming up inside the recoil housing, or an ignition component out of place, you have something in the bottom of the crank case. It doesn't take much, I had a tiny washer in the bottom of a 340S case, and it kept the crank from turning 360 degrees.
75 JD 800
Brian brought up a good point.
A broken recoil pawl was what I found once that kept a engine from doing a full 360.
I also found a dislogged magnet on the recoil twice.
However both of these problems offered only 90 degress of rotation.
On this one my orb of glass says broken skirt.
Hansy
75 JD 800
Post by Hansy »
ok, well i guess if it's not to busy at work next week i might get a chance to pull it apart and try and find the problem
