sprintfire hand grips
The dimmer switch is messed up on my sprintfire I want to keep the JD hand grips so can I get them off without cutting. If I have to cut them to get them off doe's anyone know where I can get one to replace it. PS. don't buy cheap throttle cables got two lap on the 340/s and it broke #423
Thank rich I will see if I can get them off
If you have an air compressor just blow air into the center hole of the opposite grip put your finger over the hole of the grip you want off & twist the grip while you blowing the air, it'll come right off..
Got the one off that was fun!! warming it up with a hairdryer helped( no heat in the shop maybe someday) now I need a new dimmer swicth Rich would you have one to sell Thanks Steve
