Fuel Siphoning
Spitfire79
Fuel Siphoning
Post by Spitfire79 »
Does anyone know how to drain the bottm end of gas? It appears that the fuel is siphoning into the carbs. I'm sure that there is fuel in the bottom end of the motor. Do I just run the engine or is there a better way?
Lockport, MB.
Gotta love a 2 stroke !
guitardude081
Real Name: Jack Durand
Fuel Siphoning
Post by guitardude081 »
Pull your impulse line off, put a rag between the outlet and the tunnel/wiring, and just pull until no more fuel sprays out. I'm pretty sure that all the Kawi JD's were a dry sump. It sounds like your needle/seat is leaking.
~Jack
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
