Cheers!
PJ
You know what, nix my last reply to you.....wycrumb wrote:PJ,
I have a sportfire and my powerjet carb is toast, I am putting in a standard VM34 like you did and I am wondering what jet you used in it? I am sad mine was stuck and broken but at least it will roll.
Curious "pilot needle is set at 1 1/4 turns..." are you referring to the air screw?pj sportfire wrote:I can't remember what main I have in that carb without taking it back apart again and looking, but it has a Primary Type needle jet, a 6F27 needle set at the 2nd notch from the top, a Model C main jet (can't remember the size, but I believe it's a 200) and a 25 pilot jet. The float level is set to stock specs, the pilot needle is set at 1 1/4 turns out from fully seated and the throttle slide height is set to just clear the main bore of the carb on the engine-side of the slide when at WOT. The choke cable is also set to have about 3/16" of slack, to allow for cable movement when the dash panel is in the closed position.
These settings make the carb just a ***tad*** rich, but easy to operate on this engine both cold and hot. It pulls HARD at WOT and I've got about 250 miles on this configuration with excellent results, tan plugs and pretty good fuel economy @ about 35+ miles to the half-tank full. Plus, since it's a bit rich, it covers those days when the ambient temps are very cold and the baro pressures are high. (+30.00)
Hope that helps.![]()
pj
