Drive clutch spring color
TASKY
Post by TASKY »
Just what color is the drive clutch spring supposed to be in a 80 liquifire with a comet 102c?
Out of the 4- 80 liquifires I own they all have yellowish gold color.
The 80 that I have running is just a dog out of the hole. It does not even want to spin the track. After it hits 4500 rpm it just takes off.
I am at 600 feet above sea level. I set the carbs to 82-84 specs jetting the pto side richer. The carbs have been cleaned numerous times this month. I know how important this is. Gearing is factory installed. Belt is brand new.
My 83 goes like it is supposed to with a tr800 and a red spring. Should it be a red spring? I might have heard something once about purple.
Thanks Tasky
Tasky,
a Purple spring is std. 4400-4600 RPM engagement
Green spring will give 5000-5200 RPM engagement
Gold Spring will give 5200-5400 RPM engagement
It could be that the yellow/gold spring you have is weak
There is also a Red spring M68753 for the 102's this is the one I like
are you sure that the clutch has the right weight/arm kit (AM55172 which is a "B" weight) or you can use a notched weight AM55112 (which is the high alt. weight) this with the Green M68853 or Red M68753 spring should make it move out of the hole, LOL
Rich: can you explain this?? "For elimination of the "bog", make sure the shims in the timing marks on the engine are aligned,"
What shims in the timeing marks??
Ken
Damn Rich, here I thought you were going to teach me something about the newer engines, now I only learned to make sure I proof read my posts, LOL
