http://www.denniskirk.com/jsp/tpl/product.jsp?activeTab=specs&skuId=1085&store=Main&productId=p10139&catId=308&leafCatId=30802&mmyId=
I ordered one of these shocks today for the rear suspension on my 1980 trailfire to replace AM54745. It is a front shock for an older yamaha but the dimensions are exact. 12" extended, 8"compressed, 7/16" bushings. The only that will have to change is the width of the bushings which is an easy fix with a saw or grinder or mill if you want it perfect. I will let you guys know how this turns out in the next couple days.
Travis
Possible Replacement forJohn Deere AM54745
1988 & 1991 Polaris Indy 650s
ILL POST HIS PHONE AND NAME.
75 800 440
79 TRAILFIRE 440
79 KAWI INVADER 440
06 SKI-DOO MACH Z 1000CC
79 TRAILFIRE 440
79 KAWI INVADER 440
:redface: IM SORRY,I WAS WRONG I USED 08 11416 ,THATS WHY I GOT THE COIL OVER,WORKS PERFECT
75 800 440
79 TRAILFIRE 440
79 KAWI INVADER 440
79 TRAILFIRE 440
79 KAWI INVADER 440
manitobatrailfires
Re: Possible Replacement forJohn Deere AM54745
Any more details available about getting a coil over rear shock for the TF?
Or using that ski shock from DK, 08-114-16? Did it last?
