Got my 295s engine torn apart to do a rebuild. I am planning on sending the crank to Jerome to have the seals and bearings rebuilt. I noticed that the one piston rod has a slight bit of play in it. Can this rod/bearing be replaced? Are those parts available? Can Jerome do this?
295s piston rod
295s piston rod
If the parts are available aftermarket Jerome can do it.. It might only need new shims & he has access to those no problem, also rod bearings, if it needs a rod he might be able to find a aftermarket replacement.. Or there is always a possibility that another Kioritz crank uses the same rods??
295s piston rod
The shims seem to be the issue most of the time. Big end rod bearings are not available.
