liquifire problems
liquifire_freak
liquifire problems
Post by liquifire_freak »
hi everybody i have a liquifire and last snow i ran fine rode it the whole day then this snow i but gas in it starts it up 1 pull and riding and then she starts to bog and i mixed the gas 50:1 and put brand new NGK BUEW and she is still bogging,but it wont die it will keep going but wound rev any higer then sometimes she'll clear out and run but a have a manuel and went over the whole carb top to bottom set everything at the right specs so i dont know really need some help
liquifire problems
liquifire_freak,
The first thing I would do is install standard NGK B9ES spark plugs. The BUE surface gap require a very healthy ignition system to fire. If your system is weak, this could be your problem, the bog is a plug droping out.
liquifire_freak
liquifire problems
really thats interesting i was going by what the site said BUE OR BUEW but ill give it a try thanks alot
JDFanPa
liquifire problems
Post by JDFanPa »
Ive never even seen those number plugs WTF are they for????
liquifire problems
Andy,
The BUE are surface gap spark plugs from NGK.
http://www.ngk.com/results_cross.asp?pid=BUE
They were originally recommended for the cdi system.
JDFanPa
liquifire problems
Post by JDFanPa »
Thanks Harley they just have an electrode and spark jumps to the outside of the plug right? I have physically seen new plugs like that but never in an actual sled.
