torpedo heater
sdtruck
torpedo heater
Post by sdtruck »
I have a jd topedo heater replaced all filters.when I put the shroud back on the flame goes out.If I lift the cover about 1 inch it flames like it should.I have not replaced the spark plug or nozel yet any ideas?I can see the spark plug and nozel working fine when shroud is up but cannot se it when shroud is down.
Norton
Real Name: Keith Bylin
torpedo heater
Post by Norton »
When I do winter sled work I use this type of heater (when it is not borrowed out) for the quanset. We call them Knipco Heaters. Years ago when I worked at local JD Dealer they sent me to service school on these things. The low pressure style are simple but remember they burn a flammable liquid! Check this site out for help and BE CAREFUL! http://www.croteauenterprises.com/faq.html
RAT540
Real Name: DAVE
torpedo heater
Post by RAT540 »
ALSO CHECK YOUR PUMP PRESSURE SHOULD BE A PLACE ON BACK OF UNIT WITH A THREADED PLUG TO SCREW PRESSURE GAGE IN IF YOU HAVE A SERVACE MANUAL SHOULD GIVE PSI RATING IVE GOT A SEARS CRAFTMAN 30,000 BTU AND PSI IS 3.0 LBS.
ALSO CHECK YOUR AIR FILTER. IF ITS NOT PULLIG ENOUGH AIR THREW IT WILL SHUT OFF.
DAVE
75 800 440
79 TRAILFIRE 440
79 KAWI INVADER 440
06 SKI-DOO MACH Z 1000CC
sdtruck
torpedo heater
Post by sdtruck »
Yep did all you all said next will be change nozzel and plug.I even cleaned the steel line from pump to the nozzel unit.
