lost key
chris
lost key
Post by chris »
had some guest at the house and the kids were sitting on the sleds and now the keys have walked away . can anyone tell me if any other key will fit my 1972 400 thanks.
S_Kyle
Real Name: Scott Kyle
lost key
Post by S_Kyle »
I don't know about the 72's but an 80 jag key will work in the 74 and 75 300 and 400's. I think that all the keys in the early Deere's will interchange along with some cat key's. There are alot of keys that swap between the relic sleds.
Liquifire 4/6
lost key
Post by Liquifire 4/6 »
As far as I know, the earlier JD sleds (the ones that did not use the universal Indak ignition key) had only 5 different possible keys (A,B,C,D, or E). Do you remember if there was a letter stamped into your key? If so, then just find another key with the same letter. If you look at Cat or Polaris keys, the letter designation is identified by dots in the black rubber on the key. One dot=A, 2 dots=B, and so forth. My old 76 JD 400 had a B key which would interchange with my buddies 77 Jag. Just keep trying keys and you will likely soon find one that will work.
Peter from Roblin, Manitoba
bob15
lost key
Post by bob15 »
Unplug the wires off the switch. Should start right up.
bob
79 Spitfire
lost key
Post by 79 Spitfire »
I have found a small screw driver to work on my 79 Spity
Jim
James
1979 Spitfire 340
1980 Trailfire 440
Cabindweller
Real Name: Jerry Zebro
lost key
Post by Cabindweller »
My 600 has a polaris key in it :think:
Jerry
lost key
The key from my from my Deere LX lawn tractor is the same as my mid-mount sleds.
JDFanPa
lost key
Post by JDFanPa »
most likely a screwdriver will work in my experiences
tmartin
lost key
Post by tmartin »
I have a scorpion key in my 73 400. The key from my brothers 73 panther works as well. The newer deeres use dthe indak style key like most low budget lawnmowers do. I have a toro key in my trailfire right now.
1988 & 1991 Polaris Indy 650s
