I am working on a this 4-wheeler for a friend. Problem is the electric start is flaky.
Partial disassembley shows that the problem is the starter clutch gear is loose on the shaft. It moves side to side about 6 mm.
This causes the starter idle gear to unmesh under load and the then freespin.
My question.... Is there a spacer or bushing that goes between the large gear and the crankcase?
I do not have a parts manual on this thing but do have a service manual. The service manual does not have a parts pictorial.
Anyone have experience with this or know of an on-line parts breakdown?
Kawasaki Bayou
Kawasaki Bayou
Kawasaki Bayou
www.preferredpowersports.com That should get you what you need.
