cyclone liquifire grab handles
is anyone repopping the plastic side grab handles for the rear sides of the cyclone liquifire?? 3 bolt jobs.thanks
cowboy mark
Re: cyclone liquifire grab handles
nope sorry...i have 3 machines and they're all broken off.....is there anywhere that ya can buy new ones?
Sleds owned..
1 1976 JD Cyclone
1 1976? JD Liquifire,
1 1977 JD Liquifire (parts)
1 1976 JD Cyclone
Central Snowmobile part number 13-250
Brian, are these the same as used on the 295/S & 340/S??
They're still available from a few sources however they have only the bottom hole pre drilled. You will have to drill the other two. Kenny, yes it's the same for the 295/S and 340/S. I can't confirm Brian's part number from Central but often they're listed for Arctic Cats. Stebner was selling them for something like $19.95 a pair. DA
Parts Unlimited Passenger Handle
Dennis Kirk Part #: 3974
Manufacturer Part #: 13250
Central no longer has them in stock.
The last pair I bought was from JR Graham
http://www.jrgraham.com/jrgc/hsrun.exe/ ... tCatSearch
If this isn't already in the "Reproduction" section, maybe it should be. Pretty common part. DA
I think it's in the "Parts still available other then DK, Central, etc" topic in FAQ, but it may be hard to find.
