Heat gauge-how hot is hot?
I have a heat gauge off an early 80's ultralight with a free air engine. This gauge shows the beginning of red line hot as 450 deg F. Does that sound right?
81 Liquifire
80 Trailfire 440
72 500
79&80 el Tigre 6000
80 Trailfire 440
72 500
79&80 el Tigre 6000
Re: Heat gauge-how hot is hot?
What part of the engine was the sensor located? A water cooled liquifre will run around 140ish.
This is the twpe where a washer sits under a spark plug and a connected wire goes to a gauge. It was on a free air two-cycle.
81 Liquifire
80 Trailfire 440
72 500
79&80 el Tigre 6000
80 Trailfire 440
72 500
79&80 el Tigre 6000
It sounds like the sensor is picking up the combustion temp or the temp of the head. For a free air engine, the red-line could be correct for that type of gauge.
Ok with a little research I will answer my own question. According to Rotax and the gauge manufacturer, an axle fan two-cycle, such as a 503, should have a cylinder head temp (CHT) of 350-375F. Anything in excess of 400-425F is "Hot". So the gauge I have showing 450F as "red line" hot is a little high and should be a little lower, maybe 425F.
I am not sure how all this relates to a free air engine. I once had a '74 el Tigre 440 free air, and if I am not mistaken, it had a stock CHT heat gauge, but did not show actual temperatures so I do not know what it ran. This engine never over heated, even in 40F weather.
81 Liquifire
80 Trailfire 440
72 500
79&80 el Tigre 6000
80 Trailfire 440
72 500
79&80 el Tigre 6000
My Arrow brand cyl. head temp gauges show red beginning @ 450 deg.
450 was HOT on the Cat gauges even though they went higher on the dial.
Head temp is head temp regardless if it is F/A or F/C.
