295/S Rings & Gaskets?
DLDeere
Real Name: Howard Olson
Post by DLDeere »
Where is good place to buy piston rings, needle cage bearings, circlips, full gasket set and oil seals for a 295/S?
Howard
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Re: 295/S Rings & Gaskets?
Howard, Rings are probably going to be hard to find, BUT keep looking someone might have a good stash laying around, I don't & wish I did..
I'm going to be sending Cometic gaskets a set of base & head gaskets for reproduction, they aren't cheap but they are about the best made today.. I should have a supply of gaskets in a couple of weeks.
Jerome can get you seals, I would use today's new seals rather than NOS ones as they might be hard from setting all these years.he also should be able to get you needle bearings.. the C-clips I should have used laying around here..
DLDeere
Post by DLDeere »
Kenny,
I found new oil seals, the c-clip and needle bearings that were in it should still be OK. Looking just for rings and gaskets now. Please let me know when you're gaskets are ready. Thanks!
Howard
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Howard, go to this link, http://www.silverlakevintage.com - You can order 295/S & 340/S base gaskets from them. Both the 340/S & 295/S use the same Base Gasket John Deere part number M65400
DLDeere
Post by DLDeere »
Kenny,
I've ordered the base gaskets. Thanks for tip! Now just looking for head gaskets. Can they be reused?
Howard
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Sometimes they can?? but it's not recommended.. I can spare a set of NOS head gaskets right now as I will be getting some made up anyway. email me direct ump45-nt@swbell.nt
