I'm putting my machine back together and noticed the lighting coil has a small gash in it. I can't tell if any of the wires are cut through completely. Can I run a bead of solder across the questionable wires, or should I find a new coil.
Thank's for any help.
Rob
76 El Tigre 5000 WRECKED
80 Liquifirerunning
80 Spitfirenew project
Thank's JDT, I did not test it, I might as well just get a new one. Does anyone know somebody with a NOS one, I've used an after market one before and it was a hair larger(could not tell by looking at it) and it destroyed my flywheel. I'm trying to stay away from evilbay.
Thank's Rob
80 Liquifirerunning
i had the same problem from an ebay engine the ohms were good and when added an electric start motor i could check it for ac volts on the bench you can check it with the pull rope if it ohms out good. you will see voltage as you pull. also i touched up the coil enamel with engine paint it still works i also had to solder one and insulated that one with engine paint too. jim
