invader pipes&heads
Deleted User
invader pipes&heads
what mods. do you have to do to make the invader pipes and heads fit a 1980 liquifire? How much do they make a difference. I have a invader the heads lookthe same as what is on my liquifire now.
invader pipes&heads
the heads will add a couple of hp. i don't know if the pipe will add anything or not.
- guitardude081
- Real Name: Jack Durand
invader pipes&heads
To put the heads on, you need to set your timing ahead 6 degrees, to put in the pipes, there will be some fabrication. Some things don't line up.
~Jack
~Jack
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
1983 Trailfire LX
(3)1974 295/S
1975 340/S
Deleted User
invader pipes&heads
The heads I have are off of a invader, with one plug per cylinder are these the heads people are using or is it the one off the invader ltd with two plugs per cylinder?
