frozen shafts
79 Deere
frozen shafts
Does anyone have a trick for getting out frozen shafts in the rear suspension.The front shaft came out because it was metal but the rear shaft is aluminum inside.
- guitardude081
- Real Name: Jack Durand
frozen shafts
Put the bolt back in, grab a punch, and hit the bolt. If that doesn't work, the shaft is bent (common w/ sport, and liquifire rear arms), and they're damn near impossible to get out. If you do manage to remove the inner shaft, mount a grease zerk to both outer ones to keep them moving freely.
~Jack Durand
~Jack Durand
Owner, Durand Motorsports
1983 Trailfire LX
(3)1974 295/S
1975 340/S
1983 Trailfire LX
(3)1974 295/S
1975 340/S
