WANTED TOOL BAG FOR 295/S
deere memorabilia
Re: WANTED TOOL BAG FOR 295/S
Post by deere memorabilia »
http://cgi.ebay.com/REPRODUCTION-VINTAG ... 1e5b9e8e68
I think this is the bag. Not sure but if he will get you the size I will check mine and make sure
Jessie by the picture I don't think that is it?? If I remember right it should have the zipper on the narrow/Long part of the bag, like on the side of the one pictured??
deere memorabilia
It looks like the one I have. It is not at home right now. I will try to go to the trailer and take some pictures tomorrow. I will also get some dimensions.
As Deere used some parts in common with Cat on the 295 this may well be the same bag.
deere memorabilia
Here are some pitures of the original 295/S tool bag
The reproduction on ebay is done up a bit differnt on top. If it is the same size I think it is about as close as you will find. I'm sure you would have to add your own snaps
The size is 4.25" tall
12" long
3.5" wide
jdsledsrgr8
Real Name: Matt Gabler
Post by jdsledsrgr8 »
Finally getting around to installing the tool bag. My 295s has both fuel tanks so I am perplexed where the tool bag would fit. Maybe I am misunderstanding and the tool bag would only go in the spot where the front metal gas tank is now. Any help would be appreciated.
Matt Camera 001.jpg (38.55 KiB) Viewed 2602 times
Mt. Horeb WI
1976 Liquidator
1976 Liquidator Clone
1978 Liquifire 440
deere memorabilia
Every 295/s I have checked has three snaps under the front tank. You may be able to turn it and fit it along the side.
Cabindweller
Real Name: Jerry Zebro
Post by Cabindweller »
My 295/S has the five gallon tank installed, when I removed the tank I discovered the three snaps were drilled out. I don't know if they were in the way of the tank? But they were there at one time anyway.
