looking for a track that will fit
motorhead255
Post by motorhead255 »
i'm needing to get a new track for my 78 liquifire and i would like a non cleated track and i'm looking for some input on what would fit?
78 Liquifire 440
81 440 invader ( very fast )
Re: looking for a track that will fit
A Cat track part # 01-02-294..Yokohama, 3:29 pitch is 16" X 121" But you will have to change the drivers from your 78 to a 3:29 pitch ( same as the newer Liquifires ) It would be easiest to purchase a used Hex drive shaft with the 3 drivers mounted from a newer 80-84 liquifire.. You cannot use a track from a newer Liquifire as they are only 116" the 78 suspension is made for a 121" track
