34 degree Cam Slide Shoes Buttons
Cabindweller
Real Name: Jerry Zebro
Post by Cabindweller »
Hey Guys I need a set of 34 degree cam slider shoes/Buttons. part #52995 or 53741. For my 74 600 Not sure they might be the same for all the mid motor sleds. I know they show the same part numbers for the 295/s. Is there still a source for thease out there? If not I would take a good used set.
Jerry
JFLAN
Re: 34 degree Cam Slide Shoes Buttons
Post by JFLAN »
Jerry-
Are you running a 295/s driven sheave on your 600 or is it a 600 driven sheave since they are different. I have some NOS buttons for the 600 driven sheave but not the 295/s I got them from a John Deere Dealer out in Pennsylvania about three years ago. If you want more than a few or you need the 295/s ones call your local John Deere Dealer they should be able to look up if there are any still available in any dealers inventory. Then they can order them for you or you can call and order them yourself.
Hope this helps,
Jeremy
Cabindweller
I do have the stock secondary clutch on my 600. Just need a complete set of three.
Jerry
JFLAN
Post by JFLAN »
I must apologize I missed that the buttons I have sub for the AM52995 buttons I will send you a pm with more info.
