Sporfire Engine Needed
- Danzig
- Real Name: Paul File
Gotta co-worker here at work needing a running engine for a 82-83 sportfire. Clutch and carbs and electronics not needed just a good engine.
Let me know..
Let me know..
Re: Sporfire Engine Needed
I have a twin carb fan cooled kawasaki motor. It should be a pretty close fit in the sportfire chassis. The oil injection would be the concern, seeing that it is set up like a 80's LF. Its out of an Intruder.
It would be a cool project!
How soon? Mid to late winter I'll be selling my 82 may part it out
- Danzig
This is a co-workers sled, thought he needed a crank, however it needs a cylinder only.
Anyone got a set of useable jugs to get rid of ?
This will be his son's sled, a 12 year old and the boy is anxious.
If you think he is anxious now wait till he is 17.
Being anxious with no snow.....
Maybe a Trailfire engine swap would get it back up and running too...??
I guess it depends on how original he wants it.
Doesnt our buddy near Freeport IL have an engine??
- johnnycyclone
- Real Name: Terre
I'm pretty sure Sportfires, and Trailfires share the same cylinders, just the heads are different. At least that is what I remember when I did my Sportfire last summer. I'm sure someone more knowledgeable, on here, can confirm. Anyone? That might make it a little easier finding cylinders.
Terre
Terre
I doubt that's the case, the two engines are fairly different, but I've never checked.johnnycyclone wrote:I'm pretty sure Sportfires, and Trailfires share the same cylinders, just the heads are different. At least that is what I remember when I did my Sportfire last summer. I'm sure someone more knowledgeable, on here, can confirm. Anyone? That might make it a little easier finding cylinders.
Terre
- 69camaro
- Real Name: Duane Gjerseth
Paul, I have some 80 Sportfire jugs. I am unsure if they are different or the same as 82-83.
Duane
Duane
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
- johnnycyclone
- Real Name: Terre
Thanks for the clarification Matt. I knew the cranks and cases were different along with the heads. But for some reason I remember the cylinders having the same stamping numbers. I still haven't learned, not to rely on my memory, I can't even remember what I did yesterday! How is it I could remember stamping numbers from over a year ago.Matt wrote:I doubt that's the case, the two engines are fairly different, but I've never checked.johnnycyclone wrote:I'm pretty sure Sportfires, and Trailfires share the same cylinders, just the heads are different. At least that is what I remember when I did my Sportfire last summer. I'm sure someone more knowledgeable, on here, can confirm. Anyone? That might make it a little easier finding cylinders.
Terre
Terre
- Danzig
I have a PTO side 440 cylinder I would like to sell. It is bolt on ready. Needs nothing.
Robb
Robb
- 80spitfire
- Real Name: Brian Kottke
I don't know if this helps you out, there's a bunch of sportfire parts in a lot for sale on eBay. I just glanced at it but it looks like theres a lot of usable engine parts in it. For sure pistons and a crank I don't remember what else was all there.
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
