WANTED-340 TRAILFIRE 17 TOOTH GEAR
buckeyetrailfire
Real Name: Mark Elliott
Post by buckeyetrailfire »
Does anyone have a 17 tooth top gear for a 80 trailfire 340 (part # M66302) for sale or know where I can locate one? mine is missing 2 teeth. Is this common for the teeth to break off?
Thanks for your help
Mark
1979 Trailfire 440
1980 Trailfire 340
1980 sportfire
ljm
Real Name: Lloyd
Re: WANTED-340 TRAILFIRE 17 TOOTH GEAR
Post by ljm »
You can get a new 17 tooth sproket for a Artic Cat or Polarias for Dennis Kirk.
It should pop right on.
Good luck
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
buckeyetrailfire wrote:Does anyone have a 17 tooth top gear for a 80 trailfire 340 (part # M66302) for sale or know where I can locate one? mine is missing 2 teeth. Is this common for the teeth to break off?
Mark
I wouldn't say it's common. You might want to look at causes other than gear tooth failure.
Make sure you ck the Chain for cracked or broken links ( inspect ea individually ) & look the bottom gear over good to make sure one of those broken teeth didn't damage it also.
skoalmint
Post by skoalmint »
Hello there.Im like Kenny i think somthing else could be going on.I have a matched set i believe , top and bott and chain, from one that i parted out.I will have to ck tomm. I will take 20.00 for the set plus shipping.But let me ck tomm,Thanks Brock
buckeyetrailfire
Hey guys I inspected the chain and lower gear and they both look to be ok. I did locate a upper gear from Dennis Kirk.
Thanks for the info
Mark
1979 Trailfire 440
1980 Trailfire 340
1980 sportfire
