Hi Guys,
I've had an old rear tank for my dator sitting in the garage since 2008. I just haven't been able to locate any straps (M66640 x 2) that hold the tank on, or the plates that go around the filler hole of the rear tank (M66642 and M66643).
Anyone have these parts and want to sell or trade?
Craig
dator rear tank parts wanted
Re: dator rear tank parts wanted
Craig, at least you need parts that can be reproduced easily..
Hi Kenny,
You have a good point. And the straps are hidden under the seat too so it's not that visible if I had to come up with something myself.
That said, if anyone has some pics of a used strap or pics of the filler neck plates that would really help. I could look at the cost of getting some made if there's other board members in the same boat (and if so, we'd still need a sample).
Just curious, is there anyone else interested these parts for a rear tank? Or, anyone simply make these parts themselves?
Craig
Craig
- JDXspec
- Real Name: Dustin
I made my own rear tank ring out of 2 bearing flanges. Its not original looking comparing the 2 but it still looks good. Its heavy duty like the rest of the dator. I will try to find a pic of it.
pic of mine wade
- 12-12-10 020.JPG (163.59 KiB) Viewed 1356 times
Everyone's right, just have them made. I imagine mine aren't in the best of shape, seems like I recall the rings being rough to say the least.
I could probably use a set of new straps and rings
Greg
Greg
Craig, remind me & I'll get pictures & measurements when I go up north at the end of the month
Thanks for the help. I appreciate it everyone. Will get back to you later on Kenny.
Craig
Craig
if it is just a round flat circle plate, i am sheet metal worker and we can punch in the id and od on the burn table and knock out a few. we have 16ga- 1/4 inch black iron and 26 ga to 1/4 inch galv and stainless steel. would just have to drill out the rivet holes.
