Need Secondary Cam Buttons
I need a set of AM53738 secondary clutch cam buttons, for the early Comets. I thought there was an aftermarket source for these, but can't find it now. Is there?
![USA :usa:](./images/smilies/USA1.gif)
Re: Need Secondary Cam Buttons
I'm not sure. By the picture, they look like the set I already have, which are not correct. Maybe this secondary is a later model.
Hello Matt.I have several different styles of these ramp buttons but dont have your particular part #.I have part #M63699 that is a smaller ramp than the normal ramps for my sleds.I have no idea what they fit (not in any of my part catalogs).If yours are smaller than the normal ramps these may work.They also have a slight taper on the back edge away from the cam angle.Brock
Brock, it looks like you've got a set for the Salsbury clutch.
- The S Man
- Real Name: Ron Sonnek
Matt i bought mine from jd for the gators.. When you buy the you get 6 of em'..
Ron, would you happen to have a part number? I see a couple different ones for the Gator.
- The S Man
Sorry matt couldn't find it in my mess of papers here.
