I'm looking for the heat exchangers and hoses from an 80-84 Liquifire. I plan to add this to my Dator.
Howard
WTB Liquifire Heat Exchanger
- Real Name: Howard Olson
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Re: WTB Liquifire Heat Exchanger
Howard,
I have a NOS Liquifire heat exchanger. $30 shipped to your door.
Robb
Robb
Howard I have a 80 LF i just pulled the engine out of, I am up in Hibbing give me a call 21-969-4680. Mike
'72- 400 x2, 500
'74- JDX4 Specialx2, JDX6x3
'75- 300x2, 400, 800x2 JDX8
Howard the hoses won't do you much good as you have to put longer ones on because of the up front radiator..
Got some more info and help and need heat exchanger from a 78 instead. Robb, what year is yours?
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Howard, Stick with the 80-84 exchanger, PM sent
Mine is a NOS 80-84. I believe both will work but it has been stated in the past that the 80-84's are preferred because of the smooth surface which doesn't collect dirt/mud/grime and reduce the efficiency of the cooling. Somebody correct me if I am wrong.
Robb
Robb
