need crank seals
jdcrzy
need crank seals
Post by jdcrzy »
I am in need of a pair of crank seals for 83 sprintfire - M68074. I know they are the same as the 80 - 82 spitfire and i could get a complete gasket set, but i thought i would see if anybody had a set to spare or where i might find the seals by themselves before i spend the money for a complete set just to get the seals.. Any help would be appreciated.
Joel
ChickenRat
Re: need crank seals
Post by ChickenRat »
you can buy the seals alone from www.psep.biz
Robb
jdcrzy
Post by jdcrzy »
thanks i figured that out after finding them at central snowmobile and getting a part number. They are listed under ccw engines and not kawasaki. Appreciate your response.
Joel
JD600
Post by JD600 »
Just FYI,
The spitfire and the sprintfire DO NOT use the same gaskets and it seems as though sprintfire gasket sets are becoming difficult to come by.
DE
jdcrzy
Post by jdcrzy »
yes the gaskets are not the same but the crank seals are on the 80 - 82 kawasaki motors. just need the crank seals and i have order them from pats.
thanks
joel
jdrob
Real Name: Rob
Post by jdrob »
Part number 1302r i have these in stock :) every sled i buy thats the first thing that gets changed :beers;
Jdrob
