WTB Throttle control handle
Don O
Post by Don O »
Needed throttle handle for 1976 Cyclone, AM54211or AM53582 or a way to fix short of turning new metal insert.
Don O
HoosierDeereMan
Real Name: Troy Miley
Re: WTB Throttle control handle
Post by HoosierDeereMan »
I've used the two part epoxy for plastic to glue the metal ring back into the grip before. It's still holding. If you want to go a step farther you could locate the grip in the position you like and drill a hole straight through the grip and handle bar. You can then install a roll pin to lock the grip in place. The 340/S grips are this way.
Troy
Don O
Post by Don O »
Troy,
I like your rollpin method, I talked to Howard about epoxy and his question was, what if you want to take it off?
Thanks for the help
don o
lwb140
Real Name: Wade bennett
Post by lwb140 »
ive epoxyed several of them on i think if you have to take them off they will be desroyed but as is they arent usable either my thoughts wade
