Carb cleaner?
MuskyBear
Carb cleaner?
Post by MuskyBear »
What is the best stuff to clean / soak a carb? I have some old LF carbs that are just caked inside with crud, I bought a gallon can of carb cleaner but it must have really been some cheap stuff, as it didn't even put a dent in the white corrosion caked on the bottoms of the float bowls.
Carb cleaner?
The white corrosion caked on the bottoms of the float bowls is the aluminum oxidizing. Use a cleaner such as LIME-AWAY or similiar scale removal chemical and steel wool.
