vinn and certifiction stickers
Deer'est
Post by Deer'est »
nos or repo stickers for tunnel vinn and certification anyone have or help to remake for restoration project??
thanks Forest Anderson
ChickenRat
Re: vinn and certifiction stickers
Post by ChickenRat »
I've got NOS tunnel stickers. Have reservations about letting them out. Imposter sleds could easily be made.
Robb
SpitfireKing
Post by SpitfireKing »
Can I get one for my 77 LF...there isn't one sign of any markings on that whole sled...nothing on the tunnel..under seat..under gas tank or anywhere...and I can't see where the grinder was ever used either as I stripped off all the original paint....tunnel looks all stock..but maybe it was changed early on and dealer forgot to re-tag the sled.
Certification stickers are being made by someone I think in Pennsylvania. I bought one about 3 years ago. There might be info in our FAQs section.
monte44
Post by monte44 »
I have also had the vin decal reproduced. For the 340/s
RLFollman
Re: vin and certifiction stickers
Post by RLFollman »
I definitely need two VIN tags for 80's Liquifire restores.
S_Kyle
Real Name: Scott Kyle
Post by S_Kyle »
When you guys put the new stickers on how do you expose the original vin stamping?
TASKY
Post by TASKY »
Robert, I have a Ski-Doo that could use one. LOL
jd_decalguy
Post by jd_decalguy »
SpitfireKing, It sounds to me like you have a tunnel out of Deere parts, the tunnels from the Parts dept. weren't stamped, the dealers were to stamp then when they changed the tunnels, usually they stamped them on the top ridge of the tunnel just below the fuel tank on the right side..
Kenny on Chris's computer
Chris Dotzler
Palisade, MN
lwb140
Real Name: Wade bennett
Post by lwb140 »
S_Kyle wrote:When you guys put the new stickers on how do you expose the original vin stamping?
kyle ive got one of monte44s stickers i simply put it over the stamped number on the tunnel and rubbed it on , it showed thru like a wet t-shirt contest on a breazy day worked super wade
S_Kyle
Post by S_Kyle »
I wondered if that would work or if you had to try to use a sharp instrument to trace the original stamping.
SpitfireKing
jd_decalguy wrote:SpitfireKing, It sounds to me like you have a tunnel out of Deere parts, the tunnels from the Parts dept. weren't stamped, the dealers were to stamp then when they changed the tunnels, usually they stamped them on the top ridge of the tunnel just below the fuel tank on the right side..
Yep I checked all over in those spots..no go....but I really can't see where the tunnel was changed either...how would the dealer replace the fused welds or whatever you want to call them
S_Kyle
Post by S_Kyle »
Shane, which welds are you refering to? The tunnel and pan were one unit, part # AM54198 on the 77 LF's
SpitfireKing
oh ok...I thought they had a way to remove just the tunnle.....I'll look again but it looked like spots where they were attached...that must be one helluva press to make that a 1 piece design.
80spitfire
Real Name: Brian Kottke
Post by 80spitfire »
The tunnel is one piece and then the belly pan is a seperate piece that was tig welded and rivited to the tunnel. So I guess you could say that they are two seperate parts, however they were sold and replaced as one piece.
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
