Hi
Bought an 80 TF440 just after Xmas and I luv it! However, i seem to lack top end speed. Far as i can tell i should be gettting around 6500 rpm at wot but am only achieving about 5000 according to my tach. Speedo at wot reads about 55 mph. I reconditioned the secondary clutch and am waiting for a puller so i can recondition the primary also. I suspect my primary clutch is the culprit as i also seem to have a bog/pull/drag if i cruz around 1/3 throttle - thingz smooth out when i accelerate.
Also, what would be my best setup to obtain max top end for this sled? Primary clutch spring/weights and gearing?
Any opinions??
1980 TF 440 top end & best setup for max top end
luvzvintage
manitobatrailfires
Re: 1980 TF 440 top end & best setup for max top end
Is it the right tach?
Is it actually a 440 motor?
Is the carb clean?
Is the throttle cable adjusted?
Are all your bearings good--idlers, jackshaft, driveaxle?
Is the track tensioned right?
Is the carb clean?
1979 Trailfire 440, dad bought from Steinbach, MB JD dealership in 1980 with 1,200 mile and an aluminum tunnel on it, regular rider, 5,055 miles
1980 Trailfire 340, bought in 2008 with TA440A-C202 engine in it, regular rider, 6,250 miles, LF rubber track
1979 Trailfire 340, bought in 2009, in pieces and rough cosmetic shape, 440 cylinders ready to go in (need pistons still), no odometer
luvzvintage
Is it the right tach? yes, it is....idle rpm set at around 2800 with engagement around 3600
Is it actually a 440 motor? It is an original survivor and is infact the 440
Is the carb clean? I cleaned the entire carb when i bought it (I found it very clean
Is the throttle cable adjusted? Throttle is properly adjuusted - my plug burn couldn't be better! (NGK BR8ES plugs with .022 gap)
Are all your bearings good--idlers, jackshaft, driveaxle? I believe all my bearings to be good (if i had bad bearings, would i not feel quite a bit of downshift/slowdown when releasing throttle? The sled coasts along just fine when i let off the throttle.
Is the track tensioned right? When i bought the sled i thot the track was too tite, so i loosened it up a bit as per spec. Didn't make any diff to performance.
Thanx for the reply! My sled had about 1800 miles when i bought it and it now has around 2400!
) Luv it!!
manitobatrailfires
The gearing sounds right for the speed and RPM.
Apart from the clutch, the only thing I can think of is that the throttle valve isn't opening all the way.
luvzvintage
is there an easy way to remove those beastly airboxes from the carb?? Near impossible!
I will rebuild the clutch during the off season and see what next winter brings!
manitobatrailfires
I sometimes just unbolt the intake boot from the manifold. You can pull the carb straight up then.
Vintage,
If memory serves me correctly, 55-60 mph is about all you will get out of a 40 hp Trailfire. They have large, heavy clutch weights that keep the RPM down, but I do agree that 5,000 is way too low, if that is an accurate reading. It does sound like the tach is reading a bit low, but hard to be sure from here.
I hope this helps,
-Rainville
I hope this helps,
-Rainville
