fly wheel removal
storm_00
fly wheel removal
Post by storm_00 »
ok I am at a loss once again I am tryin to remove the fly wheel so I can get to the lighting coil so I can have some lites this yr with out toatin a battery around with me I hooked up the puller an started to remove an the threads pulled out of the fly wheel is there somethin I missed I got the nut off an didnt see any ring washers that had to be removed so if anyone has any answers that would be great .
wayne.
Mailman
Real Name: Sandy Otte
fly wheel removal
Post by Mailman »
The only thing I can think of offhand is did you you use grade 5 or 8 steel bolts or just regular bolts? If the threads are stripped on the flywheel I would maybe try to tap them out to the next size SAE or Metric. There shouldn't be any other thing except the flywheel nut and washer holding the flywheel on. Hope this helps some. Mailman
fly wheel removal
Storm,
Are you sure the lighting coil is bad. Did you test the green/yellow wires with a ohm meter. The reading should be .2 ohms. The voltage before the regulator is greater than 12 volts AC
storm_00
fly wheel removal
Post by storm_00 »
thanx guys I did use the right bolts an now I have to re tap the hole but asfar as the coil working I didnt test but when I bypass the coil an put in a battery it works so I am guessing that that was the problem dont have an ohm meter to test an cant remember how to use one if I did but I will work on that good to hear from ya again harley hope your ready for another season of long drug out questions lol good thing we arent neighbors you would probly have to shoot me lol I am a bit of a slow learner so bare with me on this lol
wayne.
JDFanPa
fly wheel removal
Post by JDFanPa »
After you retap holes and get puller back on. Once you have the puller tightened up tight use a hammer and strike the puller on the head you tighten. Do this fairly firm and the flywheel usallly pops right off. However never hit the flywheel itself or you will break the magnets off.
fly wheel removal
Storm,
I would check everything I could before removing condemming stator ring. There could possibly be a loose wire in one of the connectors.
storm_00
fly wheel removal
Post by storm_00 »
ok guys I went thur all the wires an cleaned all the connections an tightend up all the connection ends I will have to find someone with an ohm meter an test it before I go any farther I will get back to ya when I find someone to help me test it thanx for the ino all
wayne
blitzblack
fly wheel removal
Post by blitzblack »
When you retap the holes on your flywheel make sure you don't go too far in or you will run the risk of bending the timing advance on the inside of the flywheel
fly wheel removal
No worries there, the flywheel used with the cdi set up does not have the timing advance on the inside of the flywheel.
