Parts still available other then DK, Central, etc.
Re: Parts still available other then DK, Central, etc.
Available from Deere:
M66005 subs to M149638 this is the rubber tank bushing that so many use.
$2.20 ea.
N132422 these are the plastic bushings used on the steering shaft. 00s, JDXs, Cyclone, LF, 340S, Dator, Spits. Much of the line up. $2.75 ea.
Head Light Lamp Retainer: Arctic Cat # 0115-285
Current JD part # for 1 inch driveshaft & jackshaft bearings:
JD9335- double seal bearing
JD8554- Bearing Locking Collar used on the secondary side Jackshaft bearing
U42111-Flangette O-Ring
The springs on the 00/JDX fuel door.
JD part number: T-15355 $9.87 as of 1-7-13
Thumb screw for engine access cover: M63672 $11.13 as of 1-7-13
Tie Rod Ends for 1982+ (serial # 190,000+) Liquifire, Trailfire, Sportfire are still available from JD. AM55391 and AM55390 at just over $40 each. These have 7/16" diameter threads.
