Hi, looking for help on motor boag. It starts fine runs fine but when stop and idle it has a major boag and if shut machine off it has hard time starting but only after motor is up to temp. Has any one elese had this problem and solved it and how?
Thanks Chris
1980 liquifire help!
- 80spitfire
- Real Name: Brian Kottke
Re: 1980 liquifire help!
Sounds to me like it could possibly be a bad needle and seat.
Brian
Brian
72' 500 Restored
74' 295/S Unrestored
75' 340/S Rider
76' Liquidator Restored
77' Liquifire Rider
80' Spitfire Restored
75' 340/S Rider
77' Liquifire Rider
You want the idle close to 3K on the 80 Liquifires. What is your idle currently set at?
It may be loading up on fuel if its idling too long. A good carb cleaning may help as well...and check to see what jetting is being used. Also check the "E" clip on the needle.
If you dont have the manual Im sure someone on here can tell you the best jetting and carb settings to use...
I do have all the manuals and carbs are clean have right jetting for the year. Thinken of jetting for a newer model and advance the timing as for idle I am at 25k so will adjust that and see how that works.Thanks for info!
Thanks Chris
Thanks Chris
ljm
- Real Name: Lloyd
one other thing... does it smoke alot?
I've had the oil pump set to put extra oil in cause similar problems..
Just somthing else you can check.
Lloyd
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
Several Kawasaki's
ACSCC #1534
