kawi invader light problem
monte44
Post by monte44 »
working on a 340 invader. I am having a problem getting the lights to work. Here is the weird part. The tail/brake light works but nothing else. There is no power to the headlight and gauge bulbs. Broken wire? I wanted to ask you guys before I started to tear into. Thanks
Sprailfire340
Re: kawi invader light problem
Post by Sprailfire340 »
Most likely suspects - broken wire or bad ground. If one part of it is working (brake light) the others should too.
:sled: ME
Invader440
Post by Invader440 »
Make sure you have the switch in the run/lights position and not the run position. You have off, run/lights, run, and start.
ljm
Real Name: Lloyd
Post by ljm »
Are you sure the headlight is good?
could be a blown bulb
Lloyd
Several Deere's
Several Kawasaki's
ACSCC #1534
