Questions about voltage regulator, elec start, and headlight
Invader440
Re: Questions about voltage regulator, elec start, and headl
Have you checked the wire runs to make sure you don't have some wires that have rubbed through and are shorting somewhere?
Viktory2k1
either get a battery or rewire the voltage reg harness. I would get the battery for electic start. The battery is part of the voltage regulation with a factory electric start unit.
Current:
77 John Deere Cyclone 440
98 Yamaha SRX700
Past:
1968 Rupp GT300
1970 Evenrude Bobcat 440
1976 Arctic Cat Cheetah 440
1976 Ski-Doo TN'T Everest 440
1978 Yamaha Exciter 440
1979? Yamaha Enticer 300
1979? Yamaha Enticer 250
1987 Polaris Sprint 340
98 Yamaha SRX700
Past:
1968 Rupp GT300
cpolaris502
I actually did just get it working... somehow. I bought a new battery last spring and never installed it until last week. I think the battery may have had something to do with it, which is very weird because I swear I hooked it up for a test right away this year and I was still reading high voltage. Later on that day as I was cleaning connections and other fall maintenance, I decided to check it again and then it magically started working.
So I am not sure if I had a dirty connection somewhere or if the battery actually solved the problem but I don't remember my exact steps I took with it. All I know now is that it works and it made me happy.
1974 JD 400
