Need drive sprockets for my JDX4 Special
jdxrobin
Post by jdxrobin »
Hey everyone,
I am looking for decent drive sprockets for my JDX4 Special (p.n. AM52078).
One of mine is fair, the other needs to be replaced...would like two NOS if possible.
Let me know.
Robin
1972 Ski-Doo Olympique 300
1972 Arctic Cat 340 Cheetah
1974 JDX4
1976 340 Cyclone
1977 Ski-Doo 340E Olympique
1978 Kawasaki 440 Intriguer
1978 Kawasaki 440 Invader
1980 Porsche 924
1985 Ski-Doo Formula Plus
1987 Polaris Indy Sport
2002 Lincoln LS V8
Thank God for big garages...and tolerant wives!.
69camaro
Real Name: Duane Gjerseth
Re: Need drive sprockets for my JDX4 Special
Post by 69camaro »
I believe a 300 would work too. I have a low mile 300 I'm parting out if that helps. I would like to sell the chain with the sprockets though.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
jdxrobin
Post by jdxrobin »
Thanks for the response.
I am actually looking for the drive sprockets inside the tunnel for the track.
My X4 is also low mileage, but the guy I bought the sled from threw a cleat and it almost ripped one of the nylon (?) cogs completely off the one sprocket.
Sliced the tunnel also...had to make a heck of a noise :shock:
One other thing, I'm not altogether sure what the best way is to remove them from the axle. They are stuck on pretty solid...any tricks or ideas?
Robin
1974 JDX4
1976 340 Cyclone
1980 Porsche 924
2002 Lincoln LS V8
A press will do the job nicely for you.
Bagoeyes
Post by Bagoeyes »
What is the type of drive sprocket??? 8 lug or 10 lug and is it round or hex axle? I can look through what I have right now in an old shop we are going through. Maybe I can help. Thanks. :P
jdxrobin
Post by jdxrobin »
...round axle, 8 cogs!
Robin
1974 JDX4
1976 340 Cyclone
1980 Porsche 924
2002 Lincoln LS V8
And I believe it should be a 1 1/8" dia shaft.
jdxrobin
Post by jdxrobin »
Got the old ones off today. Press worked well 8)
Haven't heard if anybody has any yet...the suspense is killing me.
...Buhler?...Fry?...
1974 JDX4
1976 340 Cyclone
1980 Porsche 924
2002 Lincoln LS V8
jdxrobin
Post by jdxrobin »
Hello all,
...made a pretty good size mistake.
I just checked the JD parts catalog and found I looked at the wrong section...JDX4 instead of JDX4 Special :doh:
The drive sprocket part number I need is AM52913. I then did a search for the part number and found it is the same sprocket as on the Cyclones, and Liquifiers (not the Cross Country though)
Maybe this will help a little in my search?
Anybody have any of these laying around :pray: ?
Robin
1974 JDX4
1976 340 Cyclone
1980 Porsche 924
2002 Lincoln LS V8
Bagoeyes
Post by Bagoeyes »
I have a whole lot of AM52913 NOS Sprockets!! The mold stamp says AM52913, but they also have tags on them from John Deere the say AM54216! These are hex shaft, 8 lugs. Looks like they were Liquidator ones too. 920-763-4954. Craig
The AM54216 drivers are not interchangeable with AM52913.
His X4 should have a round driveshaft.
I believe your AM54016 drivers are the optional hex shaft, 2.52 pitch versions, that were made available so you could run a production track in the Dator. I'd have to do some further looking.
Rainville would know.
jdxrobin
Post by jdxrobin »
Yep...my shaft is...uh :shifty: round
I was hoping it would be easier to come up with the AM52913.
Amazing that in this case, Dator parts are available and X4/Cyclone parts are the elusive ones.
:offtopic: Hey Craig, I have seen your ad on Craigslist, do you have mostly fire series stuff, or a bit of everything. My boy has a Cyclone and I have the X4...it would be nice to find another parts outlet.
Robin
1974 JDX4
1976 340 Cyclone
1980 Porsche 924
2002 Lincoln LS V8
