Finally a 445 in the garage!
427cobra
Real Name: Eric
Post by 427cobra »
Ive always wanted one of these... Now with the purchase of a new place I finally need one! I'll change the fluids, filters, spark plugs and Ill be ready to mow! The 60" deck will hopefully make short work of the lawn... :beers;
smitfire
Real Name: Dustin Smit
Re: Finally a 445 in the garage!
Post by smitfire »
445 should be EFI? You'll like that. I think they even have cruise control haha
Nice machine. I played with lots of these when I worked at the JD dealer.
friendlyfarmeria
Real Name: Curt
Post by friendlyfarmeria »
Hey, What's the story on the old Ford tractor in the background? Thanks, Curt
1974 400
1974 600
1974 JDX8
427cobra
Real Name: Eric
Post by 427cobra »
Yep it has EFI and cruise control. Looking forward to mowing some grass with it! From what I hear the 445's are pretty reliable machines. Anyone know of anything I should pay close attention to with it?
Its in the father-in-law's shed. Thats his Ford in the back ground....uses it for snow and leveling the gravel diveway.
It looks like a nice tractor. How many hours on the clock?
Grease the deck anti - scalp wheels frequently.
Get ready to install your favorite tape to keep the orange reflectors in place so they don't get mowed over.
Put small sheet metal screws into the tailight housings from the bottom side and against the fender to keep the housings from vibrating out. I think new ones cost $40 each minus the lens.
If it's like 455's, reverse is painfully slow. You can tweak the reverse pedal shaft clockwise a couple degrees to enhance the situation.
The side panels are pretty fragile at the corners and will crack if you drop them.....or sometimes if you don't. The lower retaining tabs that engage the frame usually break off.
Be careful opening and closing the hood. They tend to crack at the front, especially at the corners near the headlights.
Long story short, the tractor will be good mechanically but the plastic parts are brittle and cheap until you get to buy replacements.
Pat
427cobra
Real Name: Eric
Post by 427cobra »
Thanks for the comments! 870hrs
Grumpy
Post by Grumpy »
Nice find Eric, makes my 317 look vintage...
Grumpy in The NAM
Do War Protesters have reunions? IF So, What do they talk about??
427cobra
Real Name: Eric
Post by 427cobra »
Thanks Grumpy....
unfortunately its for sale now. the place we were going to buy didnt end up happening. after a bad home inspection we decided to walk away!
anyone looking for a nice 445 let me know!
friendlyfarmeria
Real Name: Curt
427cobra wrote:Thanks Grumpy....
What is a nice 445 worth? Thanks, Curt
1974 400
1974 600
1974 JDX8
427cobra
Real Name: Eric
Post by 427cobra »
Sent an IM...
