![Bonk :bonk:](./images/smilies/bonk.gif)
I talked with Wiseco about the pistons and also the WRIST PIN BEARING since I do not have enough bearings left for another run. I asked Wiseco if they had any 19 mm bearings and told me they did. I wanted to make sure that there was a match, so I sent a sample down to see if it would match up and they spent a few weeks looking for the correct size, last stop being Japan. no go....none available.
As I see it now, that give us two options. One is that you guys will have to talk it up as to who might have any of the JD bearings left. I can get the pistons made......each person has to find bearings. Option two, as presented to me by the Wiseco rep, is that we go with 18 mm pins. Wiseco has an 18 mm bearing that has the proper length and outside diameter dimensions....but an 18 mm inside diameter. Those are the two options.
I can get the run split into two parts......19 mm (you find the bearing) and 18 mm with Wiseco bearings. (Everything else about the piston will be as before).
Ok...you guys talk it up and decide what you want. I would like a committment either way so that each guy gets what he wants and nobody gets disappointed or mad. It will take about a month after everyone makes their decisions.
I think you can leave messages here.....correct me if i'm wrong....or my email address is houge@mnstate.edu and hard line phone is 218-861-6175....cell is 701-261-8214.
thanks,
certifiable.....Larry Houge
