1976 JD 400 Have spark, good compression won't start
Larrytkd
Re: 1976 JD 400 Have spark, good compression won't start
Post by Larrytkd »
lwb140 wrote:I apologize on the front end here, you've been advised by the best here and I didn't read the entire thread BUT double check the cdi wires are hooked to the correct coil or the spark plug wires aren't crossed many aftermarket cdis have the red and white wires crossed also it is easy to mix up spark plug wires many sleds have both plugs fire at the same time both sides the prestolites don't . if it wont fire on either with good spark and compression and a descent plug something is up like I said I didn't read all the dialog and maybe this has been addressed just an idea, been here done this !!!! :}} I recently converted my dads 75 400 from points to cdi the red and wire wires to the coils had to be crossed from a point set-up to cdi with a dk trader 77 cdi and pick-up coil wade
one more thought, even if you have spark check the resistance of the low speed stator wire to ground it will be the yellow wire on the stator it needs to be 2.7K ish to start and run right if its much lower you could still have spark but not enough to light a fire and run right
Wade...You win!!! I owe you a beer or two....
Mechanic double checked. he plug wires wouldn't reach across and I double checked the wiring diagram on my Vintage sled book. He found a different wiring diagram that showed them reversed. He changed the red and white and it worked. It only cost me $100 to learn not to be stubborn and although it is good to trust it is also good to verify. He has a Spitfire he wants to get rid of that runs but needs a brake disk. I haven't checked the track. I may become the owner of another green sled Larry
Larrytkd
Post by Larrytkd »
I already replaced the crank seals and now its starting after switching the wires from the CDI to the coils. Original electrical schematic had the white wire going to coil for cylinder 1 and red to 2. That's how I had it connected. We switched them putting red to #1 cylinder and white to #2 cylinder and it starts. Still needs carb adjusted. Funny thing is I used the schematic from the 1976 posted on the sled webpage.
If you have an aftermarket cdi box ,that is a common problem with the color codes.
Larrytkd
Post by Larrytkd »
The Good and the Bad.....
I jacked the track off the ground and set the carb. Slow speed out 1/2 turn, high speed 1 1/4. Set the choke...pulled it a couple times and it jumped to life....revved it a bit...opened the choke and BAM the left drive sprocket broke...anyone have a line on a AM 52563 or know of anyone who has parts?
Larry
Larrytkd
Post by Larrytkd »
Problem solved. I ordered a used part from a fellow JDsledder...
awerder
Real Name: Andy
Post by awerder »
Can anyone clarify the aftermarket CDI color code problem? Do the aftermarket CDI's simply have the white and red wires reversed in the connector? Or does this mean the red from the old CDI went to right (1) cylinder but the red from the new CDI goes to left (2) cylinder?
Glad you've solved it! I've had crossed wires on CDI's before. Such a simple fix!
