replacment carb
big jeff
Real Name: jeff
Re: replacment carb
Post by big jeff »
so after testing I found the #1 cylinder spark plug was not firing tested the coil good now I have pulled the flywheel to check the points and condenser
farmboy186
Re: replacment carb
Post by farmboy186 »
I'm curious what was your final jet set up that worked I'm going to do this soon
1974 John Deere 300 x2
1974 John Deere JDX4 Special x1
1975-77 John Deere 300 x4
1976 John Deere Cyclone x3
1978 John Deere Cyclone x1
1980 john Deere Spitfire
John Deere Sportfire x2
John Deere Trailfire x2
big jeff
Real Name: jeff
Re: replacment carb
Post by big jeff »
200 and 25
Steven Rempel
Re: replacment carb
Post by Steven Rempel »
Any idea of how many mile with those setting? and what are you current thoughts on that set up?
wow just saw the dates on this lol
Jdx875
Real Name: Eric
Re: replacment carb
Post by Jdx875 »
^^ lol I was reading this earlier, thinking wow way to revive an old post :lol22:
partspro
Real Name: Scott
Re: replacment carb
Post by partspro »
I am going to be doing this swap to my 300 also. I have seen in other posts that the stock throttle lever has to be changed to get full stroke on the throttle. There is a You Tube video on the 300 with a mikuni conversion and he is utilizing the stock throttle lever and seems to be working fine. Just curious before I get into it what handlebar alteration I will need to do.
big jeff
Real Name: jeff
Re: replacment carb
Post by big jeff »
I used the stock throttle works no problem
