'79 Trailfire No Spark
Re: '79 Trailfire No Spark
An ohm meter setting is what you need, you should be able to get all your resistance readings from the wires outside of the motor.
mrregular
Real Name: Tyler
Post by mrregular »
Ok. I checked the pulsar coil and got a reading of 21.8 ohms. Is that good?
Yes, per the diagram I posted before, which says 23 ohms +/- 20% across the red/white wires, so at 21.8 you are good. How about the red wire to ground? Should be 128 +/- 20%.
mrregular
Real Name: Tyler
Post by mrregular »
With the red wire to ground, I got 141.2 ohms. Starting to think its the cdi at fault. What do you think?
mrregular
Real Name: Tyler
Post by mrregular »
I was also wondering if a cdi for a 1980 Trailfire would work on my '79. It seems like it should, because I thought they have the same engine.
Packers29
Real Name: Andrew Engels
Post by Packers29 »
Yes it will work.
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
mrregular
Real Name: Tyler
Post by mrregular »
Does anyone know a good place to get a cdi?
rjb
Real Name: Rob
Post by rjb »
If you aren't sure how to do the ohm test I'm sure there are some videos on you tube that would help you.
Now I see you figured it out. I missed the second page of the thread.
I ordered a cheap cdi box on-line last year and it worked ok. It was black plastic instead of metal, but it seemed to work ok.
I think I found it on e bay.
mrregular
Real Name: Tyler
Post by mrregular »
Got it running!! Bought a kimpex cdi off ebay and put it on last night and it runs great now, but I wish I had some snow. Thanks guys for the help.
