What Motor is This?
big danno 1970
What Motor is This?
Post by big danno 1970 »
JDT wrote:Good eye Danno. Scorp cable end on carb bracket. You must have a huge monitor!
Nope, just got new glasses the other day :laugh: and recently spent spent a lot of time looking at on of those brackets while r&r a carb on a 73 super stingerette
Rodimus Prime
What Motor is This?
Post by Rodimus Prime »
big danno 1970 wrote:
Rodimus Prime wrote:intake is /3 covering is /2 at a guess probably a 400.
as for the fan comment jd ccw fans were all the same differences were 1 bolt on the top for engine cover and the plastic fan cover.
I hate to argue but if jd used /3 and /4 the fans are different I have both and a manual to back it up.
go ahead say whatever you want the fans are the same external for jd machines. Kohler fans are internal.
/2 /3 /5 /21 /22 engines fans are external on jds which makes them a pain in the rear for belts. actual fan housing is different between these on one bolt located ontop of fan for engine housing. otherwise they are identical.
Nice try go bs someone else im not gonna fall for it.
What Motor is This?
RP
My KEC 340s in my '72s have the fan next to the engine. INTERNAL!
NO BS
big danno 1970
What Motor is This?
i agree with yo one the /5/21/22 but before that they are internal and thats not bs. It sounds like you are a bit upset and I know that you are very familliar with this series of engines so I am sorry if I upset you but I am not going to go against the fact that the manual for these says /3 and before have the internal fan in fact it even shows the different types.
I am not an expert on this but seeing is believeing.
Your not a bit sore about the crank seal postare you?
Cabindweller
Real Name: Jerry Zebro
What Motor is This?
Post by Cabindweller »
Just got home, The motor is a KEC-340
big danno 1970
What Motor is This?
Thanks for backing me up guys!
