1. Which Comet 108 is the overdrive one? or are all the 108's OD Clutches?
2. Which is better the 4 pro 8 tower or the 6 tower?
3. What is the advantage on going to the 4 Pro?
Wanted, Comet Clutch info
- JDXspec
- Real Name: Dustin
Re: Wanted, Comet Clutch info
I believe all 108C comets are overdrive clutches. I believe they all are wider to accept the 1 3/8" belts. The 8 tower I suppose would be more durable due to more wear surfaces. The part they claim is the tuneability is you can use 2 sets of different weights to get the weights just right EX 2-29 gram and 2 30.5 gram weights. This is only my opinion I have no experience with the 4 pro.
