3 LF exhaust brackets $5 each
Lf steel belt guards -$15
rear bracket for belt guard(steel) - $5
heat exchanger bracket that clamps down on the top of the exchanger's - $5
LF over flow bottles - $5 each
LF Steel tie rods that bolt to the spindles - $20 set
LF Spindles - $20 a set
alum. air box bracket base $15
cyclone dash panel, slightly faded no cracks - $10
2 exhaust manifolds 1 440 cyclone, 1 440 LF -$15 each
2 exhaust pipes 1 440 cyclone 1 440 LF $30 each( will sell manifold and pipe combo for $40 each
440 cyclone air box complete with rubber hose, and alum grate inside - $30
LF dash council with side panels with vents $25 each (no gauges or plastic panel)
440 cyclone Mikuni carb clean with choke cable $35
rear suspension brackets (set of 4) that mount on the cross shafts and bolt to the running boards come with bolts, and brackets $10 a set of 4
have other misc. LF & cyclone parts as well if you are looking for something in particular let me know
if you have any more questions feel free to shoot me an email @ ttr50kid@gmail.com , or need more pics of a particular part, my cell # is 607-661-7981 please leave a voicemail and ill return your call, thanks Shannon
