Wanted: Cyclone Airbox Rubber Flange For Carb
anyone got one? The one on the sled i acquired is shot(torn, missing pieces) needs to be replaced. also looking for good kill switch and headlight switch on handlebars. my kill switch works but is cracked and the headlight switch is junko. other then that.......she runs like a top! let me know if anyone has anything available. Thanks!
FireRider34
Re: Wanted: Cyclone Airbox Rubber Flange For Carb
Well i have a kill switch and headlight switch il check and c if a have a flange
let me know what you want for them. these are the push button ones correct?
- johnnycyclone
- Real Name: Terre
Hoppy,
If firerider doesn't have the carb boot, send me a pm. I have one available.
Terre
Terre
FireRider34
Well i have the the switches but the ruber covers a a lil worn but no flange
BUMP...........................still in need of kill switch and headlight switch(on handle bars). Anyone?
Hoppy,
The switches you are seeking are getting very hard to find. The aftermarkets went out of production a year or so ago. Accasionally, the originals show up on Ebay. A common failure is the rubber boot splits allowing moisture inside which corrodes the center pin. The same switches were used on 74 and up JDX's, 00's, Cyclones/early Liquifires.
If you are not concerned about originality, use the later Fire-Series switches and handle-bar controls. One of the members here converted his Cyclone over and it looks very nice. Those switches are plentiful.
when you say "fire series" do you mean like liquifire and trailfire? or is fire series a brand? sorry to sound dumb. kind a newbie.
- Sprailfire340
Fire series refers to the 79-84 jd sled lineup. Most common are trail, sport & liquiFIRES.
Another definition would be the Kawasaki powered models 79-84.
cool thanks. i found an NOS spitfire i believe switch on fleabay. i havent bought it yet. think i can make it work?
what did you mean by different handle bar controls?
The newer style switches will not mount into the older plastic blocks on the handle bars. The old switches fit through a round hole. The new switches are flat and square with a "dovetail" that locks into the handle.
Nick
Nick
Here is a picture.
pictures say a thousand words! thanks now i understand.
Found some brand new original switches today!!!
both sides! sweeeeeet.
