Frosty,
I am just finishing up a restoration on a 79 Spitty. Plus, I just purchased an 80 and an 82. As far as I can see there aren't any major changes through the years. There are 3, I guess major changes to the Spitfire. As Joe stated, the track was changed for the 1980 model year, looks more like a Trailfire track. Actually the 79 Trailfire has the same track. Two would be the change in carbs. 78's had Mikuni round slide, where as the 79-82 switched to the butterfly. Either air box should work as long as you have the correct carb boot. The slide carb inlet is smaller in diameter, than the butteryfly carb. The third would be the engine change. Neither engines have points, but the Kohler runs what is called an amplifier, which adds another electrical component that could potentially fail. The cooling fins on the Kohler heads are taller, but there are only 9 of them. The cooling fins on the Kawi heads are shorter, but there are 11 total. Total surface area is probably about the same. Not sure on the cylinders, haven't looked that closely.
Chassis seem to be the same, I don't see any changes there.
Suspensions look the same also. Only difference I have seen is the rear axle went from being a round one to a square one.
Spitfire's a very light, you can pretty much toss them around where you want to go, don't think you would really need any ski spreaders.
Tracks although scarce can be found, but the price may be a little higher than what you want to pay. The last one I sold, went for $130.
Hope this helps...Terre
