piston ring compressor
mike817o
Post by mike817o »
wtb a ring comp. not having to much luck finding one! any help would be great not looking to send a ton on this tool. thanks MIKE
'72- 400 x2, 500
'74- JDX4 Specialx2, JDX6x3
'75- 300x2, 400, 800x2 JDX8
jdrob
Real Name: Rob
Re: piston ring compressor
Post by jdrob »
Mike just go rent one at your local advance auto parts or auto zone !! you just have to put a small deposit down and when you return it, they refund you !! hope this helps ! :sled:
Jdrob
Sprailfire340
Post by Sprailfire340 »
My local mechanic uses large hose clamps. As you slide piston into the cylinder slide the clamp down over the rod, loosen and remove. Use plenty of lube, don't overtighten and you will be fine. Slick and cheap.
:sled: ME
mike817o
Post by mike817o »
thanks i will give it a try
'72- 400 x2, 500
427cobra
Real Name: Eric
Post by 427cobra »
I just use my fingers. Works everytime! The hose clamps work too...
Eric A.
